godsmack635
Hello all- I have a Holley 4150 750dp that I've been trying to get tuned in. I removed the edelbrock 600cfm and have been running this new one for a month now. I rebuilt the 750 carb with the kit I picked up and had it set with stock jets and power valve. After some trial and error I'm now running 72 jets primary and 82 secondary. Not far off from stock with a 4.5 power valve as I have between 8 and 9" of vacuum at idle. The idle mixture screws are about 1 full turn out from being bottomed out. This is where I had my higheset vacuum at idle. Both float levels are correct. The engine is a 383 with Eddy performer intake, 2 1/2" hedman headers, stock heads with a pretty decent cam. I do not have the specs on the cam but it sounds pretty lumpy. Initial timing is at 24* and total at 36* running an MSD 6AL setup. I bought this carb used on CL and it seems to be in great shape other than a few helicoils I've noticed in the main body. Car was running pretty good until I stripped a float bowl screw. I took the carb off and after fixing my problem I noticed the transfer slots on the primary and secondary plates were set up different. The primary was exposed about .080 versus the secondary side being completely covered. When I had the carb mounted with this setup it seemed to run way nicer at idle. After setting the transfer slots both primary and secondary to .025-.030 each. Now it runs like crap. I've read somewhere that both slots should be evened out like this but its running like it hates it. The carb now runs really rich at idle and won't even stay idling in gear. Do I have to drill holes in my throttle blades or should I put the transfer slots back to where they were? Only reason I adjusted the slots from where they were is because I thought it might help my off idle stumble. thinking I should have left them the way they were. Any suggestions or help would be great. Thanks!
