thanks for the response...there were stock jetting for the 63 and 64 3705's..stage 2 and 3...here is a chart I found with goggle.....110 jets..for a 320 duration .520 lift factory cam..im .650 roller..so im going in the right direction with a .115--.119 jett.
1964, 426 Max Wedge Cross-Ram Fresh Air
Carb: Two Caner AFB 3705S carburetors
Manifold: Stock Max Wedge Cross-Ram
Manifold Modifications: one
Carb Specifications: Two Carter AFB 3705S carburetors
Left Carburetor
Throttle Side Diaphram Side
Primary Jet: 120-410 (.110") 120-410 (.110")
Secondary Jet: 120-392 (.092") 120-392 (.092")
Metering Rods:
PT WOT
16-76 (.066" x .053")
Right Carburetor
Primary Jet: 120-407 (.107") 120-407 (.107")
Secondary Jet: 120-389 (.089") 120-365 (.065")
Metering Rods:
PT WOT
Note: Same jets used for increased interconnection manifold (10 in.2 and 55 in.1). See Figure D.
Air Cleaner: Ideal Entry
Special Note: The modified interconnection manifold shown in Figure D has not been proven to be better than standard. Also, it has not been run on the dynamometer to revise the above carb specifications. On the 1964 Max Wedge, the increased interconnection does not appear to be a performance improvement.
cams were very diffferant from 63-64..more cam...more jett..
BTW..the .101 jets were recommended for 63 motors..heres alink for the info..from mopar performance for anuone going thru what im doing to get it close..
http://moparsofutah.websitetoolbox.com/post/Mopar-Racing-Carburetor-Manifold-Calibrations-2603834
