MoparGuy68
When I first saw my Super Bee, over a year ago, I noticed the steering column was not horizontally centered in the dash. Way back then I thought, well, that should be fixable..
Looking at it again, now prior to bolting my column back into place, and after consulting my factory service manual, I can't figure out why my mounting studs are misaligned.
There are two of them, and they are both shifted over to the driver side of the hole they protrude through. The holes are in the upside down U shaped piece under the instrument cluster. The studs screw into something else above the U shaped piece. I have not determined what is holding that piece in place that the studs screw into, or if it can be adjusted. I want to move both of those studs over towards the passenger side so they are centered in the larger holes they protrude down through.
Photos show how when I bought the car the column is shifted all the way over to the driver side of the U opening in dash. Column is right up against the driver side edge of the U. The passenger side of the U has an open gap between the column and edge of the U.
I took photos of the passenger side stud, showing how it is shifted over toward the driver side. Driver side stud is the same way. The upside down U metal piece is lined up correctly with the U opening in the instrument cluster. Whatever the studs screw into is not lined up correctly.
Does anyone know how to move the metal piece these studs screw into, or how to correct this misalignment? As I don't like it, it shifts the column and everything attached to it over toward the driver door.
