19Charger74
I have a 1974 Dodge Charger and im on a super tight budget because of college.
Shes got the 360 and it will be remaining in the car. 8 3/4 rear with 3.55 sure grip.
-Im going to remove the steel hood for a Fiberglass hood.
-275/60R15 BF Radials out back.
-Battery in trunk
-Front/rear high performance sway bars. w/ drag shocks in the rear and adjustable front shocks.
-Trans shift kit/ deep sump pan and 5.1 up kick lever
-Dual Exhaust
-Urethane performance rubber body/suspension/engine/trans bushings
ENGINE:
-#596 heads opened up with polished valves and reshaped chambers.
-Heads milled .80 to bring comp up to about 11:1
-Crosswind intake (eddy rpm AG)
-Hooker headers
-600cfm eddy carb
-Windage tray, harded dist shaft/gear, hi-volume oil pump
-MP dist set/orange ECU
-MP viscus fan.
Im keeping it very simple so i can get the thing on the road and cruise for a bit this summer. Does any one else have any other tricks & tips to make this beast alittle quicker?
With all that done, how quick to you think she'll go in the 1/4 mile?
I'm hoping for 15flat or under if it will hook up.
-Battery in trunk
-Dual Exhaust
ENGINE:
-Hooker headers
-600cfm eddy carb
-MP viscus fan.
