moparjohnny
Is there even a 4 speed or automatic crank for big blocks?someone mention the other day he has 4speed 440 crank for sale. Thanks
That's not entirely true. Many cranks that went into cars with automatics were not machined/drilled for a pilot bushing. The input shaft has to reach into the back of the crank and if it's not drilled deep enough, like shafts that were slated for use in front of an auto, the standard transmission won't mate up with the bell housing. Many end up cutting off the nose of the input shaft when they encounter that but it's not the way it should be done.theres no auto/ manual crank, your buddy is either testing you, or he doesnt know what he is talking about. If the price is right, grab it
Dats rightThat's not entirely true. Many cranks that went into cars with automatics were not machined/drilled for a pilot bushing. The input shaft has to reach into the back of the crank and if it's not drilled deep enough, like shafts that were slated for use in front of an auto, the standard transmission won't mate up with the bell housing. Many end up cutting off the nose of the input shaft when they encounter that but it's not the way it should be done.
I dug out my second crank, it's a 440 as well. Std on the mains and .010 on the rods. Both look like they're machined for a pilot bushing.NAPA used to carry a pilot bushing for this. I haven't bought one in 20 years so I have no clue if it's still offered. It's hard to tell at a glance if it's an auto or 4spd as often times the only difference is in the final ream process for the correct press fit of the pilot bushing. If it's a forged crank, it's usually worth buying either way. Especially since I'm the guy selling..... lol...but my first crank is already spoken for and the second turned out to be a 383 forged crank. Not sure that's even worth anything.
