How to identify hp manifolds
Deanfitz27
8:50 PM
Newfoundland
Does anybody know how to determine if a set of manifolds are hp and will fit a 69 roadrunner with a 440?
Copied/borrowed from Mopars on the Net;
http://www.moparts.org/Tech/Archive/motor/36.html
B&RB Engine Exhaust Manifolds
Engine Year Comments Casting #
350-361 58 Right 2205535
350-361 58 Left 2205536
361 59 Right 1739599
361 59 Left 2205536
361 60-64 Right 2205535
361 60-64 Left 2205536
383 59 Right 1739599
2205535
383 59 Left 2205536
383 60-64 Right 2205535
383 60-64 Left 2205536
383 65 Right 2205535
383 65 Left 2461307
383 66-69 Right 2532464
383 66-69 Left 2461307
383 68-69 Cuda & Dart / Right 2863000
383 68-69 Cuda / Left 2899002
383 68-69 Cuda & Dart / Right 2863900
383 68-69 Cuda & Dart / Left 2946720
383 68-69 383 Magnum / Right 2806900
383 68-69 383 Magnum / Left 2843992
383 70-71 B&C Body / Right 2899879
383 70-71 B&C Body / Left 2951865
383 70-71 C Body / Right 2899879
383 70-71 C Body / Left 2951216
383 70-71 C Body / Right 2899970
383 70-71 C Body / Left 2951861
413 59 Right 1739599
413 59 Left 2205536
413 61 300G / Right 2205830
413 61 300G / Left 1947434
413 61-64 Right 2205535
413 61-64 Left 2205536
413 62 Max Wedge / Right 2402334
413 62 Max Wedge / Left 2402336
413 63-64 300J & 300K / Right 2402781
413 63-64 30J & 300K / Left 2402782
413 65 Right 2205535
413 65 Left 2463107
426 63-64 Max Wedge / Right 2402334
426 63-64 Max Wedge / Left 2402336
426 Hemi 64-65 Hemi / Right 2465657
426 Hemi 64-65 Hemi / Left 2468658
426 64-65 Right 2205898
426 64-65 Left 2203262
440 66-68 Right 2532464
440 66-68 Left 2461307
440 67 440 Magnum / Right 2806900
440 67 440 Magnum / Left 2806974
440 68-69 440 Magnum / Right 2806900
440 68-69 440 Magnum / Left 2843992
440 70-71 C Body / Right 2899879
440 70-71 C Body / Left 2951216
440 70-71 B - C Body / Right 2899879
440 70-71 B - C Body / Left 2951865
440 70-71 C Body / Right 2899970
440 70-71 C Body / Left 2951861
361 59 Left 2205536
2205535
383 59 Left 2205536
383 65 Left 2461307
413 59 Left 2205536
413 65 Left 2463107
great response
Does anybody know if the manifolds have to be off a b body to be used on a roadrunner, for example would ones off a cuda fit, or do they turn different?
I'm pretty sure the 70 E-Body HP 383/440HP manifolds like those for 68-70 B-body are basically the same manifold, might have a different casting #... I'm not 100% sure, I know they will fit on 383/440HP, not sure if the head pipe were different or not either, you could check with Accurate Exhaust @ www.accurateltd.com/ Mopar exhaust experts
The HP manifolds are basically the same, but I think the flanges that bolt to the exhaust pipes are clocked differently on some i.e. the bolts are in different places. Matters only if you are bolting up to an original or aftermarket clone of the factory exhaust.
The flanges are different from 68-69 to 70. Original pipes won't fit. Custom pipes won't matter.
