How to install 1969 gtx side trim
minnesota guy
10:43 AM
Dassel,MN
Hi, I have 2 new quarters on my 69 GTX. Received new side trim from Moparts. what is the best way to line things up and drill once? It came with the install kit. What of those pieces go where? Just looking to be cautious vs. just jumping in.
Thanks! Jeff
Hey Jeff....Not a guru on the GTX trim. I don't know if this will work in your application or not, but not too long ago I had the drill the holes in my quarters for the clips for the Vinyl top stainless trim that wraps around the roof pillar in the back. I taped the trim where I wanted it to be secured, used a china marker to mark the outline (wipes off fairly easily), and then marked the holes where I need to drill by using that outline. Like I said, don't know if it helps with your application, but it worked in creating a template to drill with my situation
Good Luck
If you have the old 1/4s use the holes in those for reference,thats what i normally do.I take and cut the section out with the holes and hold it over the new panel and mark them out.
