FOR SALE Huge 30 year collection hemi and race parts
HEMIFRED
New Member
6:28 PM
NJ
426 HEMI PARTS
I will be selling at CARLISLE ROW R- SPACES 27-31
HEADS
Indy heads w/ titanium valves flowed around 380cfm 2000.00
VALVE COVERS
K HEAD ORIGINAL A990 COVERS, TUBES,GASKETS 700.00
K HEAD VALVE COVER GASKETS 75.00
light weight race VALVE COVERS 16 PLUG 100.00
HEMI BLOCKS
KB water block and studs 4.31” 12.5 pistons and aluminum rods 2500.00
Indy Maxx hemi block 8 new sleeves 100% like new all machine work by Bob George 3500.00
Factory HEMI lightened steel block early pro stock owned by Don Carlton bushed all machine work 2500.00
HEMI CRANKSHAFTS
New Kellogg 3.50 and 3.48 pro stock 396” 750.00
four street hemi STD cranks 400.00
GASKETS
P4120247 Head Gaskets IRON HEADS 426 Hemi Thickness: .020" Gasket Material: Steel Shim Fits Bore Size: 4.25"-4.310" 69.99/40.00
D-5 intake set
Hemi K head valve cover gaskets -75.00
4.31" HEAD GASKETS copper sets 50.00
HEMI PISTONS 250.00 SET
All Venoila
4.31 X 3.85 1.45 CH set of 12
4.375 X 4.150 CH 1.645 ROD 6.96
4.26 X 3.75 1.09 blower?
4.27 x 3.75 12.5 109
4.31 1.436 CH 10.5-1 1.03 PIN
4.34 1.98 CH 10.5-1
RODS
Child's Albert's NEW 7.185”,.990 Mopar pin 500.00
BME NEW 6.86” .990 PIN 500.00
HEMI MOTOR PARTS
MILODON PUMP COVER 75.00
SET OF +.100 VALVES 85.00
ROLLER CAMS 3 CARNES 150.00 CAN EMAIL CAM DOCTOR GRAPHS
RARE .003+ MAIN BEARING SET 100.00
ROLLMASTER CAM GEARS AND CHAIN SET 50.00
Hemi rocker stock assemblies 750.00 to1000.00
factory hemi distributors
Factory Crankshaft damper and pulley 300.00
MOROSO 10 QT.STEEL PAN 150.00
IGNITION
2-MOPAR GOLD BOXES P3690726 25.00
MSD RETARD BOXES 8981 And 8982 50.00
MSD 25’ 8.5mm red plug wire 60.00/ 40.00
MSD 31523 HEMI WIRE SET JEG'S 179.00/ 150.00
\HEMI INTAKE AND FUEL PARTS
426 TUNNEL RAM COMPLETE WITH 6214 CARBS AND LINKAGE 900.00
Factory hemi intake 350.00
HILBORN INJECTION FOR TURBO 1250.00
3 TUNNEL RAMS 200.00
GREG DAVIS SHEET CROSS RAM AND 750 CARBS 2500.00
4 sets 1150 Holleys used Holley 6214 dominators still have uncut air horns NOS 2000.00 pair
Holley 6214 dominators still have uncut air horns like new slightly used dyno pull only 1500.00
3 SETS 6214 HOLLEYS CUT HORNS 750.00 SET
DRIVELINE
Titanium cans
7.5” deep 6.1 cert 3 bolt patterns and starter pockets 1500.00
8.25” deep 6.2 cert 3 bolt patterns and starter pockets 2000.00
Lenco 3 speed trans 1.44 ,1.68 coarse spline like new 2400.00
Lenco 4 speed shifter 250.00
3 DRIVESHAFT LOOPS UNIVERSAL 20.00
2 FOUR SPEEDS “A” BODY 350.00
FACTORY 4 SPEED SHIFTERS 150.00
HURST super shifter w/setback 350.00
REARS
Dana narrowed rear housing Billet cap spool w/axles 52" flange 32" spring pads 5.57 gears 750.00
Dana gears sets NEW 3.73 , 4.10, ,4.88 used 5.12 125.00 ..NEW 4.30 175.00
Dana posi unit
9" FORD 4 LINK housing 40" flange to flange w/axles 650.00
SHOCKS AND SPRINGS
INBOARD SPRING KIT P4120665 129.00/ 85.00
8.75 SNUBBER P3690182 60.00/ 40.00
New KONI SINGLE ADJ REAR 1907SPA 600.00/ 300.00
ALDEN FRONT SHOCKS “A” BODY COIL OVERS 200.00
Used double adjustable REAR 1907SPA 300.00
MANY SETS NEW REAR SPRINGS 110LB 90 LB
HEADERS AND EXHAUST PARTS
426 Sanderson street rod block hugger headers used on dyno have EGT bungs welded in tubes. 250.00
426 HOOKER 2.25 4” COLLECTOR RACE “A” BODY NEW AND COATED 800.00
FLOWMASTER Scavenger Collector C214234400 2.25" X 4'" X 24" JEG'S 140.00 SELL 90.00
SAME AS ABOBE 2.125"
FLOWMASTER Outlaw Series Mufflers,Inlet: 4''Outlet: 4''Length: 16-3/4''
JEG'S 90.00 EACH WILL SELL 125.00 PAIR
Flowmaster 954540-10 Delta Force Race Muffler 4.5”
JEG'S 140.00 EACH WILL SELL PAIR 150.00
WHEELS
Super tricks 3.5 5 sets and 15x12 a few sets 150.00 UP PER PAIR
Welds rears different widths and back spaces
Convo Pro 3.5 x 15” 4.5” 15x15 rears full set used 450.00
CENTERLINE WARRIORS 3.5 X 15 NEW IN BOX 150.00
RACE AND OTHER PARTS
FRONT DRAG TIRES
Goodyear 26” #1964 26 x 4.50-15 SUMMIT 175 each. sell pair 250.00
Hoosier #522-18095 DRAG FRONT 24.0X5.0X15Front Drag Tire JEG’S 150.00 each SELL PAIR 200.00
E BODY CUDA NEW FENDERS, DOORS AND HEADER BY VFN 750.00
E body VFN Cuda cowl hood 10” tall .300.00
DUSTER FIBER GLASS TRUNK new in box 150.00
K&N STUB STACK 1050 85=-0600 20.00
HI BACK BUCKET SEAT FRAMES 300.00
THERMO QUAD CARB 9247S 440 TRUCK AUTO 50.00
THERMO QUAD CARB 9371S 50.00
Mopar RADIATOR B/B 2898 069 XHEAVY DUTY 100.00
CNC DOUBLE MASTER CYL 125.00/ 85.00
SYSTEM ONE FILTER ASSEMBLY 100.00
426 HEMI CUTCH FAN CORE AND NEW FAN AND BLADE 250.00
440 CAM AND KIT STOCK COMP 75.00
AIRHEART BRAKE HATS NEW 300.00
JOINT JIGGER STILL IN BOX 180.00
B/B WEDGE ENGINE CRADLE NEW 100.00
E BODY HOOD PINS BRACKETS AND LANYARDS 100.00
16 VOLT TURBO START BATTERY CHARGERS 150.00 EACH
INDY REVERSE COOLING PLATE 50.00
NOSTALGIA PRO STOCK PARTS FOR SALE
6214 1150 HOLLEY DOMINATORS WITH AIRHORNS UNCUT NEW AND USED
6214 1150 HOLLEY DOMINATORS WITHOUT AIRHORNS
HEMI TUNNEL RAMS,
SUPER TRICK WHEELS,
MALLORY SUPER MAG ONE UNITS
CABLE TACHS,
16 PLUG RACE VALVE COVERS
16 PLUG ACCEL DISTRBUTOR WITH COMPLETE DUAL CRANK TRIGGER ASSEMBLY
E BODY CUDA FIBERGLASS FENDERS AND DOORS BY VFN
SNORKLE HOOD SCOOPS
NARROWED DANA W/AXLES
ASST DANA GEARS
MAX WEDGE INTAKE 3705 CARBS,LINKAGE ,FUEL LINES COIL AND BRACKET SAT ON SHELF FOR THE LAST 40 YEARS 2500.00
MAX WEDGE BARE INTAKE
FACTORY STREET HEMI OIL PAN NEEDS WORK CXAN SEND PICS MAKE OFFER
got any complete street hemi's?
426 HEMI PARTS
HEADS
VALVE COVERS
HEMI BLOCKS
HEMI CRANKSHAFTS
GASKETS
D-5 intake set
All Venoila
4.34 1.98 CH 10.5-1
RODS
HEMI MOTOR PARTS
IGNITION
DRIVELINE
Titanium cans
REARS
Dana posi unit
SHOCKS AND SPRINGS
WHEELS
FRONT DRAG TIRES
HEMI TUNNEL RAMS,
SUPER TRICK WHEELS,
CABLE TACHS,
SNORKLE HOOD SCOOPS
ASST DANA GEARS
Do you have any complete street hemi's? Built or un built
Got any complete, built or not street Hemi's?
Parts
do you have any complete street hemi's? Built or un built
- - - updated - - -
got any complete, built or not street hemi's?
[ delted by staff - no phone numbers in posts - use the PM function ] anytime
Need a set of super tricks 15 x3 front and 15 x 14 or 12 with 5 inch back space.
Interested in the 4.30 diff. will it fit in my dana 60 ??
30 years of parts
Are the Indy heads for a Hemi or RB 440? And are you only selling these items at the Carlisle show?
thanks
426 HEMI PARTS
HEADS
VALVE COVERS
HEMI BLOCKS
HEMI CRANKSHAFTS
GASKETS
D-5 intake set
All Venoila
4.34 1.98 CH 10.5-1
RODS
HEMI MOTOR PARTS
IGNITION
DRIVELINE
Titanium cans
REARS
Dana posi unit
SHOCKS AND SPRINGS
WHEELS
FRONT DRAG TIRES
HEMI TUNNEL RAMS,
SUPER TRICK WHEELS,
CABLE TACHS,
SNORKLE HOOD SCOOPS
ASST DANA GEARS
any chance that you have any fiberglass bumpers for a 70-72 cuda? thanks
