Hundreds of NEW and used parts for sale
truetriplex
6:27 AM
Ball Ground, GA
Feedback: 3 / 0 / 0
After 30+ years of Mopar restoration, it is time to retire. I am in the process of compiling a list of items that should be of use to some of you. Mostly B body, some E body, and many convertible pieces. I have HP motors, date coded carbs/distributors/manifolds/alternators, etc. Remember, if you don’t see it, you may want to ask. And you are free to throw me an offer too. If you have a specific part your are looking for, the easiest way to see if it is here is to use the Year One part number to search the list
Many items are NEW still in packaging and are so listed. There may be some shelf wear. For reference purposes I have tried to list part numbers (mostly Year One, Mopar, OR OTHER). Items may NOT be from these suppliers but are always top quality that I used in high end restoration. Again, I do this for reference only. You can check the YO web site to see if this is the item you need. Price does not include shipping or handling. ALL ITEMS ARE LOCATED IN SOUTHERN CALIFORNIA
69 Plymouth quarter extension gasket 2 sets $15/pr (each set)
68-70 B body – molded door ends (ALP7001 NEW in bag) (reference to FR474) $30
66-70 B body 151329 Fire wall gasket kit W/AC (NEW in bag) x2 (reference to XH89) $27/EA
67 Plymouth B body BBE6767TL101 tail light gasket set $25
68-70 charger fuel filler neck seal (reference to AO708) $15
68-70 AC box Heater bypass valve “h” valve O.E.M. $140
66-67 HLS016 Plymouth headlight seal NEW (reference to SF1) $35
68-70 B body HS 66 firewall AC gasket set (NEW in bag) (reference to XH99) $30
68-70 B body CH2077 hood to cowl (NEW in bag) (reference to CC2077) $15
68-70 B body FFRT010 head light seal (NEW in bag) (reference to SF3 ?) $10
68-70 B body POST CAR headliner side trim pieces $50
68-70 B body 2 sets coat hooks $10/set
66-68 – B body center console top shift plate A/T (decent condition) (reference to CT6B) $125
66-68 center console glove box plate (Fair condition) (reference to CDB68) $75
66-68 Shift knob (spring + button) fresh chrome (reference to SK669) $50
68-69 Used button gear shift $5
Center console slider NEW (reference to ACR670) $15
67 Plymouth window cranks (set) NEW in bag with spacers (reference to MH67) $45
69-70 RR interior trim screw set (NEW in bag) (reference to SK170) $35
68-70 charger (DF2) door lock Ferrell (reference to FW817) $12
68-70 B body Upper Seat belt retainers shoulder harness (reference to SBC6P) $45
58-70 Bench seat hinge covers BLACK (NEW in bag) (reference to W668) $40
Clutch return spring (4 speed Assembly) $25
69 Charger sun visor w/ rod (1 only) $40
68-70 13” charger Arm rest pad – black $10
68-74 window cranks set (NEW in box) w/ spacer (reference to BN17) (2) $25
66-67 B Body Package tray jute NEW (reference to PJV66) $15
68-70 B body inner door pulls ATP 146 (NEW in box) (reference to DP68) $30
68-70 B body Arm rest base 3-9 1/2” 4-11” chromed and ready $45
68-70 B body inside header trim panel clip $15
B body – 6 way seat release/ knobs/ 2210SK (NEW in package) $35
Center console light housing $70 for the set or $45 each
68-70 rear interior upper door frame for POST car $65
68-70 headliner side trim for post car $65
68-70 headliner side trim for non post car $65
DASH
68-69 B body non-rallye Instrument cluster bezel (reference to GB687) Needs replating cost $90 approx. $90
69-71 B/C and 71-74 E body AC heater control units 3895790 x2 (reference to FD5790) $80
68-69 Plymouth AC center vent – mounting bracket $45
68-69 B body Tach/clock block out plate non rallye $25
68-70 AC center vent Extremely nice $60
A/C vent w/o vanes $10
68-70 B body Speaker hold down plate $20
69 AC heater control DASH switch w/ vacuum assembly $85
69 B Body 3 sets carb air cables ORIGINAL (reference to AO191) $60/ ea
67 upper dash pad core only $40
68 upper dash pad core only $40
Got any 73/74 roadrunner charger parts?
I need rear seats for 1970 charger will 1968 roadrunner rear seats fit I need anything for the 1970 charger. grill wraparound filler, grille, 4spd manual tunnel, 4spd manual console top plate,Engine parts? BB bellhousings, etc
Im searching for a REVERSE light that mounts on the interior lower dash for a 4 speed car if you have 1 available.
Hi, can I see this part anywhere?
Thanks!
WANT: 70 B-body headlight/dimmer rheostat rocker switch assembly or whatever year might also fit.
do you have any of the clips for a 70' GTX inner door woodgrain panel? the panel is maybe 3" wide and the length of the door. any help would be appreciated
One more time? This one part might not be worth your while, but a response would be appreciated.
Thanks!
Just following up to check on this?
Thanks!
Thanks!
Looking for the rear window plastic interior trim for a 68 coronet. Really only need then passenger side upper side piece. Let me know if you have anything.
Thanks,
Jason
