Hydraulic cam and lifters for sale-CCA-21-223-4
Red63440
1:41 PM
NY
Feedback: 3 / 0 / 0
Comp cams 21-223-4 BB cam
Hydraulic flat tappet
Basic Operating RPM Range 1,600-5,800
Intake Duration at 050 inch Lift 224
Exhaust Duration at 050 inch Lift 230
Duration at 050 inch Lift 224 int./230 exh.
Advertised Intake Duration 268
Advertised Exhaust Duration 280
Advertised Duration 268 int./280 exh.
Intake Valve Lift with Factory Rocker Arm Ratio 0.477 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio 0.480 in.
Valve Lift with Factory Rocker Arm Ratio 0.477 int./0.480 exh.
Lobe Separation (degrees) 110
Camshaft Gear Attachment 1-bolt
Computer-Controlled Compatible No
Grind Number CRB XE268H-10
Notes Single-bolt camshaft.
The cam was in the engine for 300 miles or less before it was pulled. Included are all the lifters (CCA-822-16) which are also Comp cams. All lifters have been boxed and marked for location.
$70.00 plus the ride.
Reduced to $50.00 plus shipping
Sale pending......
