Hydraulic lifters
5.7 hemi
12:40 AM
TEXAS
Can you adjust hydraulic lifters with the motor running, assuming adjustable rockers?
Good question!
Personally, wouldn't think so. Solid lifters need a gap, to allow valves to fully close. But, hydraulic lifters need a pre-load on them, with the plunger set .010 - .030, or there abouts.
not with the screw and jam nut adjusters. very difficult with the old interference thread adjusters; i know from experience. best answer is: don't.
You can do that with stud mount rockers but not shaft mount.....
Thanks guys!!!
I asked because if they are not TOTALLY correct from the get go, and you have a few that are clicking, then using a cut valve cover one could adjust the lifter(s) and be bang on correct. So that is why I posed the question.
