HyperFlex Master Kit on a 64?
Yes it will fit. ALL b and e bodys use the same front end parts from 1962-1974, of course they may be some exceptions, but your good if you use these parts on your car.
Thanks. :)
I actually don't need it now as I just ordered a front end rebuild kit from p-s-t.com. But still good to know that most of the bits are interchangable.
No all B and E body cars did not use the same front end. 63 to 69 B body cars are the same. 70 to 72 B body and 70 to 74 E body cars are the same. And 73 to 79 B body cars are the same. The K was changed in 70 placing the sway bar above the K frame. In 73 the B body cars got completely different K frames with sliding upper control arms attached to the K frame instead of the inner fender.
I have a 64 dodge polara. The kit at P.S.T say its for a 65-76.
That would work for me, correct?
The only thing that will not work is the idler arm, 62-65 are different than 66-70 b body and the 70-74 e body. All the bushings will work fine and so will the tierods. Do yourself a favor and upgrade to the 11/16 tierods and adjusters, they are much beefier and bolt right in, the 11/16 are c body parts. Now are you totally confused?
The pitman arms are different too. There is a large and small sector shaft. The small one has 4 indexing splines, the big one has none.
