I have a service manual and have used the Instrument Panel Wiring diagram for my guide but can't find the three wires I need to connect. I had removed my dash cluster to install new lenses. I re-installed the dash cluster and the following items work: headlights and the wipers, interior light when I open the doors. None of the gauges work ;Fuel, oil and rpm. I have a new fuel sending unit and ground. I have been under the dash looking for any wires which are not connected and found Three (3): a male RED WIRE that comes out of the harness just to the right (view under dash) of the radio and a DOUBLE RED wire with a Grey male Connector(photo attached) , which is just under the glovebox and the third wire is the white wire with red female connector (photo attached) that is spliced into another white wire that is attached to the radio. I have a service manual and have the Instrument Panel Charger wiring diagram but an having trouble locating where these three wires connect. I have attached a photo of the DOUBLE RED wire, which I tested with the engine off and it is a live connection with power. Any thoughts are appreciated
