I hope so
daredevil
1:23 AM
houston tx.
Had a leaking axle seal on my beater s-10 work truck,96 model 235k on the clock.Got everything back together and cover back on rear and filled it up.Used about a 3 inch piece of clear silicone plastic hose on the gear oil bottles. End of the last bottle I squeezed a little too hard and shot it in the fill hole. Screwed the plug in. Dont have time right now to drop the cover again. I,m thinking the gears ought to just grind the soft hose into silicone additive in my oil. Hence the title of this thread. I hope so.
oh boy...i dunno bout this one DD.
that's a lot of extra material in an otherwise pretty tight spot(s).
might be easier to get the whole hose outta there in one piece instead of a sh*tload of little pieces later...
I bet it lasts as long as the truck does. I,m out of here at 5am so not much choice. If it causes a problem another rear can be had for a hundred bucks. If it hadnt happened at 7pm i would have pulled the cover but it was getting dark and I was doing it on the patio.At least its not abrasive.
True dat.
Good Luck, and Godspeed D!!
i think you will be fine.my buddy throughs wood chips inside worn rear diff's on his work truck beeters to make em last longer(after they start making noise),and it works.wood and plastic are about the same toughness.
Well,,,, if the back end of the truck winds up pointing the wrong direction, you'll know that it locked up!
Sounds like trouble to me.....
Well, it's hard to predict what will happen - unless you fill the rear end with metal chips, ceramic beads or steel ball bearings. That piece of hose may do noting or it may do something. Just keep an ear out!
Sort of related example, my 02 Durango had a funny whirring sound when making a tight turn, like driving in a parking lot, but was steady for a long time (meaning not getting worse), but after about 50 K miles I thought I'd have a look. I pulled the cover off and immediately see one of the half round tubes that act as a barrier between the limited slip clutches and iron carrier was broken in pieces and stuck to the magnet at the bottom of the case, which looked like a porcupine from all the metal shavings, and the other half round piece was also broken and loose but sticking out of the carrier and rubbing on the case generating all kinds of metal particles. As I later found out this is a common problem with the 9.25 rear end in the late model Dodge trucks.
Me thinks that whirring sound was coming from the LS clutch pack because it was asymmetrically loaded since the one half round was in effect missing from the clutches and only part of the other side was still in place, and with a 1500 mile road trip coming up, I too didn't have time to deal with it. So I got the hammer and punch and proceeded to break the remaining hardened half round tube out of the carrier to at least put the clutch pack square or flat and cleaned off the magnet, put the cover back on and filled with oil. This was 100K miles ago.
The piece was that soft clear tubing like aquarium air line only 1/2 inch. 150 miles so far and alls good. Probably no different than when people slop rvt all over the covers and it squeezes inside.
Yall are all crazy.
...and your point is?
I kind of with Mario on this,but...the short length may be a benefit IF it settles to the bottom of the diff. Another but...if it gets caught between the ring and the pinion,might it put a bad twist or something similar on(more than likely) the pinion gear? I understand the situation,DD,but,but...
235 thousand miles on it. Theres an 1/8 turn of backlash play in the gear set. Hell its loose enough it could probably chew aluminum stock and not quit. One day I will pull it apart and see if I can find any of it.If this had been one of my mopars I would have worked in the dark but this is more like a demented science project.
And this is where my nickname Daredevil comes in.lol Living life on the edge.
235 thousand miles on it. Theres an 1/8 turn of backlash play in the gear set. Hell its loose enough it could probably chew aluminum stock and not quit. One day i will pull it apart and see if i can find any of it.if this had been one of my mopars i would have worked in the dark but this is more like a demented science project.
- - - updated - - -
and this is where my nickname daredevil comes in.lol living life on the edge.
lol....
LMAO. That's too funny. I just finished reading the funnies here on another thread and I still can't stop laughing on this here post good one guys. LOL.
Six months and nary a whimper. Guess its just silicone additive by now.
Daredevil, you must have better luck than I do, it would have caused some catastrophic failure if was in something around here...LOL.. {Not really}
i know the tubing you are talking about and it is super soft.if you are lucky it will put a nice coating of plastic on you ring and take away some of that play.i dont think you need to worry at all.prob just like addative at this point.
