if gas prices wernt bad enough
1976_newport
8:07 AM
nova scotia
ok the title may of threw u off a bit but i am in the process of buying a intake to switch my 440 - 4 barrle into a 440 duel 4 barelle ...im just woundering what mesuerments i should take to see if it would line up or what (never realy switched a intake befor )....so if any one could lend me a hint or show me a site saying what to do ,,,,,and 1 more thing...whats the toruqe specs for the intake bolts?
A short block is the block and internals. A long block will also include heads. So, except for the heads and pushrods and rocker gear, no. No difference. Unless the intake is made to be used with raised port heads, then all is well
I seriously doubt you have enough motor to make running a dual quad setup worth wile
