troublemaker
So here's one for u. Brand new ignition switch, brand new wiring harnesses throughout car, new starter and starter relay. Car starts 90% of time. Occasionally when you turn the key in the on position and go to start it there is no contact with starter. With ignition on i can jump the starter at the relay and start the car. All contacts at relay and firewall clean and tight. The ignition switch has no accessory power, when i roll the switch to back toward me its dead all the time. I wonder if the switch is bad or indexed wrong, if thats even possible. This is a 4 speed with a clutch safety switch. Makes no sense. Any help appreciated.
