Phantom440
Hey all, hopefully you guys can help me out-
Got a '71 Coronet, converting it to a floor shift. Got the steering column collars from an 80s fullsize Ram, everything's going together great. Put my old ignition switch in, slid the new (72+) key cylinder in, but the hole on the cylinder doesn't line up with the switch pin. The pin is rotated too far forward (toward the dash). If I put the key in and turn so the hole lines up with the pin, the cylinder goes in all the way. If I then try to turn the key back to "off", it won't let me, it only turns back to "on" or so... What'd I do wrong?
