Ignition switch with cornering lights?
Cornering lights are an option on c bodies, what was able to turn on a light on fender just at a side of the sidemarkers, to light up when turning, to get a better view on sides.
Turning switch ( no ign switch ) is the device what turns on this lights coming from the extra harness. You simply won't use it
But regular turning switch without that extra harness are available around. That's the one you need. Fender turning lights are simply an splice from the existant turning system on forward lighting harness
I have a 72 Charger with fender mounted turn signals. I need to replace the turn signal switch for it. Non tilt. I seen this one. Is that what they mean cornering lights? Fender mounted turn signal lights? http://restorationpartssource.com/c...db0&ss_parm=A0d79058ff0c414ad268c9bc4782d6a82
Hi. I just posed the same question recently. What i learned is, fender mounted turn signal lights & cornering lights are not the same thing. Cornering lights are mounted low on the side of a fender. They lit the curb as you turned. Fender mounted turn signals are on top of the fender. The switch for a car with curb lights usually costs more.
