timbotim
New Member
i need help how to change out the ignition switch on my 1972 charger..?
You'll need a steering wheel puller. A lock-plate spring compressor is helpful too...they're pretty inexpensive (don't even bother getting a loaner from AutoZone or whatever...the ears are gonna break off and you'll end up buying the thing anyway). Aside from those two things there aren't any other special tools involved. If you have the key getting the old one out is easier. The new one should have some rudimentary instructions with it.
Make sure the front wheels are straight before you pull the steering wheel. Depress the lock plate against the spring enough to remove the snap ring. If I remember correctly the turn signal cam has to be unscrewed and moved aside, then you can access the small spring-steel tab that holds the lock cylinder in place. Turn the key, depress the tab, and remove the lock cylinder. Installation is the reverse of removal. Not a difficult operation, but it may take some patience and, as a bonus, you'll gain an understanding of how things work inside the steering column. Knowledge is good.
