Mopar-Charger
I need help i've tried everything...
I have a 360, dual plane, 750 cfm, headers, mild cam, 727 torqueflite
First off where do i set timing? I have a timing light. I have 10, 0, -10 marks. where between those marks do i place the dash? I've tried nearly everywhere, currently it's at -5 roughly, runs like ****. Hates the cold mornings.
Secondly kick down linkage: my new Holley has a larger throw than my Edelbrock. Now I have a 1/2inch gap before the throttle engages with the linkage. I have to do this to obtain WOT with the kick down stopping it short. However it takes forever to get moving at a stop light, so i put a bolt in the 1/2inch gap. which seemed to fix it, but it now cant reach WOT.
Also feels as if the tranny isn't full engaging? RPMs climb but the car feels slow and sluggish. (used to have no problem getting up and going)
Third problem is flow. I have cutouts which give me an amazing 3500-5500 RPMS but I lack the low end. When I run exhaust I can't keep traction from 1000-4000 RPMs then performance plummets over 4k. What should i do to get the best performance? I have Long Tubes - 3inch - 40 series flowmasters - 2 inch. Again i have a tall gear in the back I shift 1-2 at around 50 MPH (5500RPMS)
One last thing, my power steering pump pulley belt whines? I've replaced the gear and pump but there is still the problem. Sounds like a dying whale when I get on the gas, will this harm my performance? I can see the belt moving, but the pulley is still.
Thank you in advanced,
Jake
Jake
