1966 Hemi
Need A little help again!!! My reverse T on the shifter is not sring loaded and i think it should be?? The car also has a console...I think that i read that there is a cable inside the shift tube? Correct? Is the shifter able to be removed with out removing the console? I think that all i need is to remove the handle to replace it?? Ideas or direction would really help. It still will go into reverse but i want it to be correct....HELP!! -Rich
