Installation of Tic-Toc-Tach
Moparmann
4:32 PM
S.E USA
Hi All! I have a Tic-Toc-Tach that I want to install, replacing my clock. I need advice/guidance, as I've heard that the tach will not work w/ electronic ignitions. I have a Pertronix installed in my car. I also have the factory wiring connector for the TTT. Thanks for your assistance!
:thumbsup:
My tic-toc tach worked fine with a pertronix ignition before restoration. On the restoration I went back to points and the cluster has been restored and updated by Red Line Gauges. The pertronix that I used was the basic kit with their upgraded coil.
Thanks for the response. That's good to know! I just have the basic Petronix w/ OEM coil.
Installed a tach where the clock once was, line from neg coil and to power for the gauge light...I have an early gen electronic ignition. I checked the accuracy with my timing light and all fine.
