Verify height gain of aftermarket vs the OE manifold. Is there that much intake throat on the air filter base that can be cut off and still retain the carb attachment diameter ???
3/8 of an inch. Why I told him to verify the height change from stock.. and can he cut that off the 383 intake throat if it's still carb intake diameter at that point..
https://www.trickflow.com/search/pr...-manifold-height/5-750-in?N=602215+4294960302
Manifold height on the Trick Flow for a 383 engine is 5.75". This is about 2 3/8" taller than a stock intake. Good luck getting that to fit under stock air grabber ductwork. Using a 440 air cleaner base will give you about 3/8", but you still have a loooong way to go.
We used a Weiand Action + along with the 440 base air cleaner on my 69 Bee. I was also able to use a 3/16" carb gasket. Not sure if your 71 has any more room than a 69?
