Darth Ooten
I'm having some weird issues with the lights in my 1968 Gtx. First some backstory. This all started when I decided to fix my fuel gauge and figure out why the horn wasn't working. None of the gauge cluster lights worked so while it was out I installed a new circuit board and led bulbs. The wiring was a mess and rather than patch it back together I ordered a new under dash harness and installed new turn signal switch.
Now for my problem. When you turn on the park lights everything works, same when you switch the headlights on. The emergency flashers all lights work as they should but the dash lights flash as well. If you signal left the dash lights flash and both taillights blink. If you signal right dash lights don't flash, front and rear work correctly but the side markers don't come on.
Reinstalled old circuit board on cluster same result. Wiring seems to be solid free of damage. Grounds are clean. The fact that the passenger side market lights work under certain circumstances is what's really got me stumped.
Any thoughts?
Any thoughts?
