dsd1967
I should have numbers tonight so here's the combo. What are your guesses.
440 based 512 CI
10.6:1 CR
Mopar Stage VI heads w/the following flow numbers
Lift Intake Exhaust
0.100 90 72
0.150 136 123
0.200 170 145
0.250 202 177
0.300 232 199
0.350 261 217
0.400 285 230
0.450 304 240
0.500 309 248
0.550 318 256
0.600 322 260
Hughes Cam HTL5660BS3 flat tappet, solid
lift intake .579" exhaust .587
duration at .050" intake 256, exhaust 260
LSA 108
850 cfm quickfuel carb
victor intake w/ 2" four hole spacer
comp cam stainless roller tip rockers 1.5 ratio
FBO ignition system, mechanical advance 20 degrees initial, 14 added by 2900 rpm
Based on other builds I've seen here, I've got a number range in mind....any guesses where it will end up?
440 based 512 CI
10.6:1 CR
Lift Intake Exhaust
0.100 90 72
0.150 136 123
0.200 170 145
0.250 202 177
0.300 232 199
0.350 261 217
0.400 285 230
0.450 304 240
0.500 309 248
0.550 318 256
0.600 322 260
LSA 108
