The 68 FSM says .101" and .089" for the AVS with 1-11/16" primary and secondary throttle bores. Metering rods are 16-542 for manual and 16-546 for auto, but no measurement info on the step diameter. I may have a set I can measure but not where I am at the moment.
Well, then that changes everything. Jetting is not determined by the engine but rather the venturi size. Should be easy to find info for the Eddy carb.
If you look at the Edelbrock manual it gives a table for selecting the jet / rod combo to give a specific A/F ratio. Start with the middle setting, which should be how the carb was shipped.
