K Member Bolts
Robliepse
7:55 PM
Buford ga
Does anyone know where to get new K Member bolts for my 1972 big block?
30 bucks plus shipping for 4 bolts! Dang. I might have some extras laying around or someone here does. I don't save junk so if they don't have to be new, save yourself a few bucks and go with used ones. I know they can rust but there's lots of good used parts still floating around....
If you don't care if they're original, try clipsandfasteners.com . They have a huge assortment of, uhhhh clips and fasteners. A great source. The 3 radial lines indicate a Grade 5 bolt. They have the body and frame bolts with the built in washers.
Got mine from Frank Baldeson. When I put mine in, they'll have anti-seize on them.
thanks guys, I saw them on E Bay but Ouch, 3 of mine still look good and I only need one.
If you use other than the factory ones, the pix look like they have a hardened washer under the head. I am not sure what function the integral tapered shoulder has, unless it helps to retain the bolt in the frame during assembly into the car.
Have you tried moparmarks or Moparparts on here?
