Paul Cotton
My 65 Belvedere keeps losing the ground connection to the left rear tail light. Anyone have a suggestion on how to cure this once and for all.
I was thinking about doing this very thing. Wasn't sure if it would work. I think I will go ahead and give it a try, thanks.Solder a jumper to outside of bulb socket and over to good ground on body?
I was thinking about trying the separate wire but hadn't gotten around to doing it. I think I will try it as well as the electronic cleaner. ThanksI ran separate ground wiring to all housings front and back. The sockets can loosen and a little corrosion between the sockets amd housing or inside the sockets will cause random problems. I scrubbed these areas with a small steel brush and a bit of electronic cleaner.
Thanks for the reply, I will give the grease a try as well.di-electric grease where needed to help stop corrosion .
Oh I've had them do that, years ago. It'll drive you nuts!KK yeah laugh ur butt off! It'll happen to one ur sockets one of these days!
Jeff
And the dash clusters are all electronic. One company I worked for had all IH trucks. One after another were having electrical problems.And then the real fun part of grounds are the semi-trucks; 100,000 miles a year and in the winter, pounds of dry/wet road salt screwing up power/grounds to lights like you wouldn't believe.
