Key ignition switch
PolaraFury
3:44 PM
MN
Where can I get the key ignition switch? 67B Body.
I don’t need authentic I just want it to work.
I replaced the relay on the firewall and when I hook the battery up the motor cranks.
Why did you replace the relay? Un plug the ign switch first and see if it still does it. The switches are all over the Net,,,
switch
switch
I replaced the relay because it wouldn’t do anything when I turned the key, but it would crank if I jumped it with a screwdriver
switch
I unplugged the ignition key switch and it still cranks when I hook up the battery
Your thought please?
I would do more diagnosing before replacing more parts. Start with new relay. Didn't crank with old relay and now cranks when battery is hooked up. Sounds like another bad new part or it isn't wired correct.
I second that!
Yep start relay is stuck closed or the coil is getting energized from some unknown source
