HemiMagnumRTAWD
If anyone has the manual scanned for a 3 piece kickdown linkage adjustment please share.
I pinned the upper pivot(on the intake) and pulled up on the trans rod and adjusted it to fit. My book then says unpin it, and to remove the return spring(did not specify carb or kick down) and push the rod rearward and adjust the rear of the eye to the throttle shaft. I figured it meant the kickdown spring...
