Labored steering
sebring+
2:51 PM
CA
Hey guys,
1972 sebring+, 400.
Removed power steering and installed manual.
Steers good except for one small issue.
At turning when I get to about 45° off center in a turn, the steeringwheel it is a bit labored.
I have to hold a little tight and keep a bit too much tension on the steeringwheel.
Not bad though.
Any thoughts?
I'm thinking TOE is off slightly.
In or out?
Maybe someone knows.
Toe in makes it want to go straight. (Too much toe in will put excessive wear on the outside of the tire edge)
Toe out makes it wander and want to follow the road.
I am thinking that there is a bind in your steering column. Everything relaxed and aligned properly. Recently had this issue with my Dart.
