- 8:42 PM
- Apr 13, 2012
- Granite Bay CA
Have you ever had a Hi Stall torque converter that makes your car feel too lazy?
I have a 70 Charger with a 493 mill. 10.8 squeeze, '509 cam, Edelbrock heads, 850 carb. The 727 has a 9 3/4" converter rated to 3000 stall. I have 3.91 gears in the 8 3/4" axle and just for fun, I added a Gear Vendors overdrive.
I've had this converter in the car since 2006 and have never liked how loose it feels. I have a 2007 Ram truck with a 5.7 HEMI. I like how it feels tight right off of idle. My brother in laws 72 Duster, 360/904 also has a stock converter that pulls right off of idle. This Hi stall converter though...
It feels tight when the converter reaches 2500. It will start to move the car right off of idle, but I can feel the slip. I feather the throttle to speed up, but the car doesn't speed up in direct proportion to the engine speed. I talked to the guy that built the converter. He said that he might be able to cut it apart and swap in a different stator or something to reduce the stall. I wonder if it is possible to reduce the stall by 500-700 rpms?
I have a few 12" converters here, but I suspect that they are the super low 1200-1400 stall units, spec'd for a Chrysler Imperial or some other land yacht. That would obviously give me another set of problems.
What are your experiences?
