TorRed
- 8:32 PM
- Dec 12, 2023
- The Villages, Florida
Hi All,
So I was T-boned in an intersection while driving the Roadrunner. I was stopped waiting for traffic in front of me to move and a drunk driving a large Pontiac ran the red light on his side and ran straight into my passenger door. A buddy was sitting on that side and got knocked into me. The window glass shattered into a thousand pieces and I'm pretty sure I was outside the car running around the back to get at the driver before all the glass landed, seriously. His window was open and I jumped right through it to get both hands on him. He started blubbering incoherently so I knew I was wasting my time, but I was still furious when the cops showed up. The bird was hurt but still drivable. The big nose of the Pontiac hit the center of the passenger door bending it in at a sharp angle. The door was still locked and actually opened and closed afterwards. He also hit the passenger front fender before he was done.
The Body shop found a second hand door and fender to put on, repainted the whole car in the wrong color, supposed to be Torred, think they went with Vitamin C orange or something similar and the car has stayed that way until I pulled it apart years later and discovered the body shop filled in a roughly .5 - .75" gap on the back top of the fender where it met the cowling and door. The door gap is fine, the only issue is up top. The patch was Bondo so I wire brushed it away and tried to see if the fender could be re-aligned but nope, now there was a fender/cowl gap mostly on the outer edge before it turns down and meets the door. The part of the fender I'm talking about is crescent shaped and the fender/cowl gap is close at the engine bay side but widens further out. I wish I could show it to you but since I was doing things on the cheap back then I just used fiberglass in the same spot and that's how its been for probably 35 years now. Any idea what fixing this correctly is going to take? Without looking at the car one shop said the frame could be bent, but somehow I don't think so since everything else lines up. I'm thinking it was either a bad replacement fender or the cowl was 'tweaked' and may need to be pulled out. Looking at the cowl everything looks good so I don't know how to go about fixing this? I've traced the curve of the good side of the cowl and flipped it over onto the passenger side and it seems to match. The 'curves' on the fender and the cowl both look right, they just move apart towards the outer edge. Any assistance will be greatly appreciated!
Thanks,
Jim
Thanks,
Jim
