Icke
I have a problem, I have almost no idea about the electrics, can somebody tell me what the individual names on the light switch are for, B1, B2, I, etc.? I have a guess, but before I connect something wrong, I'd rather ask.
I have a 72 satellite, the light switch is aftermarket SMP-DS16571 satellite? Or what have you got there.
Sorry, I should have written about it: The plug only hung on a cable when I removed the dashboard. At some point, a new wire harness was installed, so that the colors do not match either. I have to track every cable now.If you have not disturbed the wires in your harness and plug, you should be able to just plug it into the switch. Or does the switch have a different configuration?
Thank you very much !!!!
Where can you buy something like that as an alternative?They are wire splices, originally taped up inside of the dash harness.
