'Lil help please...
2059
11:29 PM
North Central Indiana
Could i get one of you guys w/ a 64 330 2DR post to take a few shots of the interior around the headliner perimeter. I am particularly interested in the transition from the headliner to the package tray cover and through the sail panel area in the rear. I know i have the garnish pieces for the upper front window but not sure about the rear window.
thanks in advance.
I have a 64 Belvedere 2 Door post. I'm sure its the same. There is no garnish at the bottom of the window. The sides and top of the back glass have 2 U channel plastic L shaped pieces that slide over the headliner where it is hooked on the toothed surfaces around the edge of the window. They meet at the top center of the glass. The only other trim goes around the flanged edge inside of the quarter glass. This a flexible vinyl/cloth covered material. There are 2 steel garnish moldings that screw onto the B-Pillars. The other 7 steel pieces are for the windshield. Be aware that the upper wind shield molding screws into 4 brackets and not the roof structure itself.
I have a spare set of brackets if you don't have them.
Doug
Thanks for the help!
By what you said; I'm missing the plastic u channel pieces and the flexible vinyl at the quarter glass. what brought this up is when we started finish painting the metal garnishes and thought there were some pieces missing. I'm covered with the inside A pillar brackets.
They repop them,Kramer and others.
Doug
