Can some one post a diagram or picture on where the studs go, by length and what the correct intake bolt markings are for a 1969 Dodge Hemi. Thank you,
The intake manifold is installed with 6 studs of 3 different lengths. 10 hex head bolts 3 long and 7 medium length with specific head markings and grade criteria different between the 2 sizes. Than 3 extra short hex bolts for the 3 brackets, that do not go through manifold. Again a specific head marking, and grade. It even seems coating was different on the 3 versus 7 bolts. Additionally, the washer head size comes into play with the 3 small bolts. So for concourse installation, or someone trying to make it as it was suppose to come from the factory, it actually would matter. And I am not sure the kits are correct. This is for 69 hemi, 66-67 used allen head bolts, and not sure if things changed for 68 or later models. Conventional wisdom states 68-71 are the same.
