The wiring diagram that 68GTX440 posted shows a 3 prong relay. The center terminal is constant power (violet) the left terminal comes from the horn button (Dark Green with Red Trace) and the right terminal (Dark Green) goes to the horns. Give that a try.
Seriously? the ignition coil. No, relays use a small coil to create the magnetic force that pulls the switch in.747mopar : Hope you're not talking about the ignition coil...
Try this for a universal wiring diagram of a horn. Just connect the two horn terminals together for duals and make sure the horns are both grounded.
Yeah, I guess your right it might be confusing but I did state "relay coil" in my post. I always find these problems easier for someone to understand and figure out if they understand how it works, not just telling them where to put which wire. If you know how it works you can figure it out pretty easily. Your welcome for the education, next time maybe we can not take pokes at someone for trying to help.Yeah. Thanks for the education...however, there is a real need to be specific. Can you see how a novice might misinterpret this?
"(one to the + side of the coil and the other to one side of the relay switch) then run your horn ground to the other side of the coil and your horn feed to the other side of the relay switch."
Here is a schematic that will show you the wiring to and from
View attachment 119289View attachment 119290
