kb67mopar
I have 2 small block 360 blocks both are rebuildable. 1 needs a honing (has small damaged spot on bottom of 1 cyl from previous rod contact but was rebuilt and ran afterward by marshall engines) and the other needs boring, honing and cam bearings
Coming with these blocks are:
(1) 2-barrel intake manifold
(2) 2 sets of small block heads, casting 915 and 576 ...1.88 intake, 1.60 exhaust 1 set completely rebuild, the other in need of rebuild.
(3) 2 360 crankshafts, 1 is .010/.010 the other factory (i think)
(4) 2 - truck oil pans with pickups and oil pumps
(5) 16 rods and pistons
(6) 1 camshaft with lifters
(7) 2 sets of rockers with shafts, bolts and keepers
(8) 2 timing covers
(9) 2 harmonic balancers
(10) 2 electronic distributors
(11) an assortment of pulleys, water pump cores, power steering pumps, starters, brackets etc.
I also have an Edelbrock Performer dual plane intake for sale for an additional $125 and a holley 3310 750 vacuum secondary carb for $100.
Essentially what is here is from the tear down of two complete engines, one of which was a very low mile reman engine from Marshall engines.
Total for both blocks and parts (excluding carb and manifold) I am asking $300 or make me an offer.
Parts are near Chicago. both engines are tore down to the block.
(8) 2 timing covers
