FivePointParts
Hi There! Please feel free to ask any questions about the engines. I did my best to get the casting info. If you want build date info let me know. These Engine are located in the Pacific Northwest. Thanks! -V
1) 67 440 C440 6/30/66 Standard bore, good core out of 67 Chrysler $1500
2) 67 383 C383 9/20/66 Good core $1200
3) 71 383 HP G383 HP long block with 452 heads standard bore 7/8/70 $1800
4) 76 440 6T440 core long block 6/7/76 $800
5) 76 440 6T440 core long block standard bore 2/6/76 $800
6) 58 325 Poly Dodge Spitfire Core turns over $800
7) 72 340 complete core 5/26/72 $2600
8) 69 440 E440 long block 9/28/68 $1500
9) 72 340 w/ 518 4 speed OD trans both rebuilt engine casting 2/8/72 Weiand 8007 intake, 30 over, ported and polished heads, deep sump oil pan, lopey cam, may come with headers.. $8000
10) 69 440 1/13/69 BLANK PADS A12 candidate?? Turns over. Contact for more info.
11) 65 383 A383 1/22/65 turns over $1000
12) 71 440 HP G440 HP manifolds, dual valve springs, 906 heads 1/21/70? 71? Probably 71. Was rebuilt not so long ago $5000
13) 67 440 HP C440 rebuilt 30 over, 906 heads, adjustable rockers, 292/509 cam 1/5/66 $5500
14) 73 440 J440 Standard, rebuilt, double roller timing chain, new valve seats, 6/14/73 $3500
15) 77 400 rebuilt 10/31/77 $2500
16) 70 383 HP F383 out of 70 Challenger R/T 906 heads, HP springs, core 9/8/69 $1800
17) 69 440 E440 runner 20k miles on the engine 1/18/69 $2000
18) 69 383 E383 core 8/6/68 $1000
19) 72 440 new timing chain, HP valve springs, new freeze plugs, seals, gaskets, 4/3/72 $2500
20) 68 383 HP D383 3/28/68 Contact for more info
21) 62 361 HP core out of 62 Dart BIG HP stamp 9/10/61
22) 56 341 HEMI DeSoto Fire Dome Rebuilt $5000
23) 69 383 HP E383 516 heads, HP springs, rebuilt, 8/26/68 $3000
24) 73 440 HP J440 core, comes with 516 or 452 heads 1/29/73 $1500
25) 71 383 HP block w/ crank 8/11/70 $1200
26) 72 340 w/ 360 heads, out of 72 Cuda, rebuilt 30 over, adjustable rockers, dual springs, Edelbrock performer, low miles 6/14/71 $4000
27) 67 318 w/ 727 rebuilt 8/31/66 $2500 SOLD SOLD SOLD
28) 69 383 HP E383 rebuildable core, 906 heads, 402 oil pan, 3/8/69 $1200
29) 66 273 core 8/24/65 $500
30) 73 440 J440 valve job w/ HP springs, RV cam 1/22/73 $2800
31) 74 440 HP Cop car motor? Steel crank, 452 heads, rebuildable core 1/8/74 $1500
32) 64 413 w/ 516 heads 7/24/63
33) 73 413 Industrial motor 9/8/72 $800
34) 51 Lincoln 337 flathead V8 complete core MAKE OFFER
35) 71 383 G383 core block w/ mains 452 heads 8/21/70 $500
36) 67 383 C383 core block with mains & crank 7/28/66 $500
37) 63 318 POLY ST318 complete motor stuck 12/5/62 $500
