451Coronet
So just rebuilt the front end of my 'Net and was going back thru and checking and tightening everything when I noticed the arm on the lower ball joint that connects to the tie rod is hitting the backing plate and is not fully seated. They came in a new poly rebuild kit from Just Suspension. Would it be okay to grind some off the backing plate a bit, I dont really wanna be grinding on my LBJs??? There's maybe about 3/16" space by the bolt where the backing plate bolts to the LBJ.
