Commando66
I’m going to be replacing the lower ball joints on my 67 Belvedere. My question is, do I need to back off the torsion bars before I split the spindle and ball joint?
Annnnnd just like that now you do. http://www.mymopar.com/index.php?pid=109I don’t have a FSM.
If the car is blocked up under the k frame or the sub frame, then you have to. If you block it up under the lower control arms then you don't, but make sure it is blocked well.
