Mopar Fan Dan
Is there supposed to be a cover for the lower steering column on a 1968 Coronet standard dash? My car does not have anything under the steering column and the lower dash pad that wraps around the upper portion of the column is not tight against the switch plate. Is there supposed to be a lower column cover that helps tighten everything up? I found a lower steering column cover on ebay but I am not sure if it is for a standard dash or ralley dash. Any pictures of a complete standard dash would be great.
Dan
Dan
