Cheetah RMVB is hardest shifting simplest VB on the market. Ran a couple back in the day on the street. Never knew of the low band apply issue.. guess I was lucky.
Transgo-TF3 I installed recently on the other hand is a nightmare to install, shifts ok but nothing like the Cheetah RMVB's did. One of the valves that needs grinding in particular, is like get f*ck out. Transgo should include one already modified. And I can't even tell if the low band apply is working properly, so im still making sure to always shift to 2nd while under power from 1st gear, in any throttle situation.
Moral of the story, get a $185 Cheetah RMVB from Summit, your 727 will last forever, and run a trans blanket "just incase".
All of this low band apply stuff.. well if one day your "low band apply" VB decides to not function correct or your band slips ecetera you risk an explosion anyway................
