Longknife
When I purchased my '69 RR in 2019 it had been converted to (non power)disc brakes with the adjustable valve to the rear and a new master cyl. The brakes worked great and stopped the car very good. After a summer of driving, the brake pedal seemed to be getting low. It was solid but would travel about 1/2 way to floor before pressure was felt and then it would stop great.. A single pump would bring the peddle back up to the top. I tried adjusting the rear brakes but it made no difference. I put the car away for the winter and next spring I checked the brake adjustment and even bled the brakes but a test drive confirmed they peddle was still going too far down and the more I used the car the farther the peddle went down. A single pump would bring the peddle back up. I purchased a new MC, spring of '21 and installed it and that brought the peddle back up where it needs to be and stopped the car nicely. Now that cyl is doing the same thing. There is no more than 5,000 miles on this car and I have gone through two master cyls...???? This is the one I purchased last spring,,,What gives?
https://piratejack.net/1960-1970-mopar-master-cylinder/
