Hi all,
Early on in my car build I did a lot of research on brake MC bore sizes and went with a Raybestos blue 15/16". Stopping is adequate, but pedal feel is not. MC and brakes have been bled 3 times by pro shop. I'm finally finished with most of my build and want to get better brake feel. Here are the specifics:
68 satellite, power brakes, front disc/rear drum. 8" dual diaphragm booster, 4 piston wildwood dynalite calipers up front, rear drums with reduced bore wheel cylinders for brake proportioning.
Current MC is 15/16" raybestos blue. Car stops, but pedal travel goes too low before full bite. Overall pedal feel is ok, but cannot stop as quick as I want. Brakes and MC have been bled by shop multiple times.
I'm going to try a larger MC to see if the fluid can fill my caliper pistons more readily, but I still want a nice feeling pedal that I can modulate.
For those who have been down this road, what was the result of you trying a larger MC bore size for power disc/drum? With power disc/rear drum and the wildwood dynalite's, I'm not sure which of the following would be best:
1.00"
1-1/32"
1-1/16"
1-1/8"
Seems like such a 1/32" or 1/16" of an inch can make a big difference. I don't want a rock hard pedal, but I want the brakes to grab before the pedal is 4/5 of the way to the floor.
I'm also not sure what is available from which makers. Thinking of sticking with Raybestos, but I'm open to suggestions (except I am not considering hydro-boost). I do know about some of the folks out there like Dr Diff, but I want to hear from my mopar brothers and sisters if you were able to correct the same issue I'm having.
Thanks in advance!
1.00"
1-1/32"
1-1/16"
1-1/8"
Thanks in advance!
