master cylinder
moweepea
1:10 AM
Nampa, Idaho
Need to change my single master for a dual on my 63 polara 383. Could someone walk me thru this, as far as which one will fit, and I guess I will need a new(can't think of the name) block or valve, is it called a proportioningvalve?? Thanks
I'm doing this procedure as we speak. I'm building a 63 Polara (Max Clone) for street/strip driving. I'm installing a 70 Coronet master cylinder right to the fire wall. Use the new proportioning valve. Pretty straight forward. If you change the length of the pedal bar that attaches to the cylinder inside the firewall, just re-drill a hole to match the length you need.
I dont know if you want power brakes or not. Vacum assisted or?
Anyway, look up Master Power Brake and see how they do it. I am not a "FAN" of theirs, they use GM crap but, the instructions should help.
