Pretty much anything you want because that's not such a high area that timing won't take care of any anomolies you may encounter. Octane might be an issue but at 10:1 you should be OK. Besides, due to climate warming, you'll be at 0 feet above sea level in the very near future and wished you had built a submarine instead.Anyone have advice on the max dynamic CR I should build for with only 92 octane available and running between 0-500 sea level?
Alot severe LOL!!!!!!!!!! On 93 pump gas I found that 8.5 Dynamic on Cast iron heads with manifolds as the limit. 9.0 with aluminum and headersOuch, 10:1 dynamic might be just a little severe.
chassis dyno? peak horsepower on a chassis dyno won't be at the same rpm as an engine dyno. takes power to drive all the parts as the drive train increases in speed. I don't pay much attention to horsepower numbers on engine dyno stuff anymore. I will take notice of comparing parts or combos on a given engine. the only power that means anything is where the rubber meets to road.I am here to learn. Any knock issues in the past were at lower RPM's. Dyno says no more power after 4850.
