max wedge hoses
mxwedge
1:36 PM
Ohio
I'm still looking for a set of Heater Hoses for my 64 Plymouth Max Wedge! I only need the long hoses, NOT the whole kit some vendors are selling for app $200. My brackets and all other parts are on my car. None of the major parts house can get them long enough with that molded 90 degree on one end. Thanks for any help or leads.
Is it safe to assume you are set on being 100% correct with this setup? If not you could always buy small right angle hoses and use hose connecters to get you there with a long cut of 5/8" hose. Obviously it wouldn't look factory....but it could hold you over until you find what you are looking for.
Thanks, but that is what I'm using now. Looks terrible at shows. Would like to find correct looking hose. They do NOT need to be "correct stamped". Just two, 1 piece hoses would be a big improvement. Mike
Building off of 70rr's idea you may look into the Parker Push-Lok line of hose couplings. The whole deal with those is no clamps are required so the junction will be much less of a sore thumb.
