max wedge rocker stands / valve cover spacers..need help
6T5
4:55 AM
Washington state
1 - Installing old cast stands on shaft and, pow, split in two pieces (looked like old crack...they are also really galled from overtightening)
Surely there must be something better. Mopar performance has some machined stands and then there's some on Ebay from Billet Racing Parts our of Michigan...any other sources?
2 - I'm putting on Crane 1.5 aluminum rockers. Will they clear my four-bolt stock valve covers with a .560 lift cam?
If not, where can I get spacers or is there a four-bolt valve cover that is shaped somewhat like stock that is taller? (something I could paint and keep my max wedge looking stock)
Thank you
thanks. The email link on their website doesn't work .. do you know how to get ahold of them?
I had Harland Sharp 1.5 aluminum rocker arms on my motor with a .510 lift and they hit the baffles on my stock covers. I had some 4 bolt spacers made and then had cometic make some 5/16" thick gaskets. They cleared but I constantly was fighting leaks. I ended up changing to Comp Cam's steel rollers which are a lot smaller and went back to stock FelPro gaskets. Of course, you have a lot more lift. Good luck. I believe the source shown only does the spacers in 6 bolt, which will fit, but look kinda funky...
