BB69R/T
I purchased a Solid State Voltage Regulator from Year One (part #346) for my 69 R/T Coronet. I am currently using a grounded brush alternator, stock ignition, points, condenser, ignition coil. Has any one used or switched to this voltage regulator or solid state regulator? is it compatible with my current alternator? (in the past I have had good luck with Year One tech support, but not this time). I know that mopar switched to Solid State regulators in 70 using a different alternator types. My issue is inconsistant voltage after start up. I get a good 13 volts on start up, but after a few minutes voltage drops to under 12 at idle or driving down the road. Battery is not being fully charged. Last resort today is to try and adjust the current mechanical regulator. Any thoughts or expierences are greatly appreciated. Thank you very much.
